wheel specifications for M3 performance
brett
Inlägg av brett »
HI does anyone know the wheel specs for 19" wheels for the M3 performance
i will keep the 20" for summer fun, but want something a little more forgiving in time for winter..
BTW that is why we have Chill mode for winter only is that correct :P
Sorry for my english but when your ten year old tells you that you suck at swedish !!!
Johan84
Re: wheel specifications for M3 performance
Inlägg av Johan84 »
Hey, I also ordered a p3d and have looked into this and I think I know how I’m going to do, but not sure. I drive on dirt roads a lot and going to sell the original 20” rims and going for 19 on summer and winter. The tire spec is 19x8,5 and 235/40/19 and et40. The problem is the bolt on the nav that sticks out 4-5mm. You can chose on going for a rim that makes space for the bolt or going for a spacer that you drill a hole in for the bolt. If you going for a rim that is flat on the backside and need to have a spacer and it’s important to go for a rim with a HIGHER et to get it further IN so the wheel position is the same as standard with the spacer of 5mm (et 45). The nav circle on the oz wheel I have chooses has a nav circle of 75mm and standard is 64.1 so I need to make some adjustments to the ring also. Look at this video in the middle that has been posted here before. This is only a problem for the performance. All sites that sell the wheel I’m looking for does not have fitment guarantees for p3d so it’s important to order the correct fitment because it’s not possible to send back.
If I will fit the bolt in the cutout in the rim I’m going for a et38 and will put on a 245/40/19 tire to protect he rim a little instead.
Don’t know about chill mode. I think the track mode is for the winter ;)
