Har du en dashcam?
- vinothkannan
Re: Har du en dashcam?
Oh thanks Mattias.. I will give a try and wait for your pictures.
https://www.kjell.com/se/sortiment/dato ... tar-p98847
can i use this instead ..? will it work..?
MX100D-AP3-FSD
- mattiasottosson
I actually bought that too, but unfortunately it won't work since one of the females from the Y-split only have three cables, and it dosen't match the once you need from the original cable.vinothkannan skrev:Oh thanks Mattias.. I will give a try and wait for your pictures.
I forgot that i actually taped everything together in an ugly hidden mess, so I'm afraid that the pictures won't help really.
Two things that will make your live easier when installing the rear cam though:
1. Buy spare blue clips, it's very easy to break them when removing the rear trim pieces. SC has them, or you can go with these:
https://www.navringar.se/plastclips/toy ... ps-pl-2064
2. Sand down the rear cable, making it a bit smaller, round and much easier to pull it through tight spaces.
3. Skip the middle clip of the right side trim panel and pull the rear cable through there, instead of going the whole way round the trunk as daerik does. Then you don't have to remove that big trim piece.
If you're lucky, you can pull the cable trough that tiny space that's along the top trim piece in the top of the trunk, but the cable gets stuck very easliy. Mine did, and it was a pain to set it free.
S75D (uncorked), pano, midnight silver. | Model 3 reserverad 2016-03-31
http://--- -> 9000kr rabatt + Fri supercharging.
- mattiasottosson
- vinothkannan
Eller så gör du som jag och borrar ett litet hål bredvid den gula kontakten och tar den därigenom, det förenklar väldigt när bakre kameran ska monteras.
Model 3-24/Polestar 3-24
- vinothkannan
hej..
I managed to get the power supply..once and later on i didnt get any 12V power ...Any idea wat cud have went wrong..?
MX100D-AP3-FSD
- vinothkannan
I have made the connections as per Derek from YouTube. I was able to get 12V once and later I replaced with new wires since I made bad insulation to the wires.
But I don’t get any power for my BlackVue
MX100D-AP3-FSD
Det här var en ganska trevlig lösning för alla som har en Blackvue. Blir en integrerad och diskret installation!
https://tesland.com/en/product/blackvue ... for-tesla/
Kanske någon här med 3d-printer som kan göra lite business
Här visar DaErik hur man installerar samt hur resultatet blir
Vet inte om det finns någon CAD-modell på den där men även om det finns eller ritas upp så blir inte kvaliteten och finish lika bra med 3D-printat,
fast visst vore det lite ballt
- vinothkannan
jag har en fråga...!!
Strömförsörjningen bakom backspegeln är konstant som OBD..?
MX100D-AP3-FSD
Nej, den är inte konstant på Model X i alla fall.vinothkannan skrev:jag har en fråga...!!
Om någon liksom jag gått och velat kring inköp och väntat på någon form av tecken så har det kommit nu. Blackvue 750S nedsatt 1 300 kr till 2 690 kr å Elgiganten.
Svart X75D -17
- danni
- Kontakt:
Oj, det var ett bra pris! Synd att jag redan köpt en 900
Har också en DR900s nu! Trevligt..
Men har inte hittat nått bra program att trimma HEVC-filer med utan att behöva konvertera om. Använde MpegStreamclip förut och det paketerade bara om h264-filerna så att man kunde spara just den del som var intressant och inte hela filen. (känns onödigt ibland att spara kanske 2 minuter för att man behövde 10sek i slutet av en och 10sek i början av den andra.
Stör mig lite på att 900an har lite väl mycket vidvinkel. Det framför en blir så smått och det är ännu svårare för folk att bedöma avstånden i klippen.
- danni
- Kontakt:
Jag har inte fått min kamera monterad än, så jag kan inte prova, men jag brukar redigera filmer i Final Cut Pro X, som klarar HEVC. Även gratisprogrammet iMovie ska klara det.
Jodå, FCP X klarar det galant. Bara det att jag är lite av en horder när det gäller data. Alla klipp jag sparar ner lagrar jag sen också på nasen.
Då försöker (har jag försökt) hålla nere storleken lite på filerna genom att i MpegStreamclip först spara ner bara den del jag vill spara. Nu blir det till att spara hela filen istället.. Och ibland två filer även om situationen bara varar i 10sekunder..man kan ge sig faan på att det händer nått intressant just under en skarv.
En fråga som vi inte har lyckats få svar på än
Vi funderar på att köpa den enklare dashcam som installeras bakom backspegeln. Som jag fattat så är det inte konstant ström där. Men aktiveras strömmen på något sätt om man tex blir påbackad, så att chansen finns att fånga någon på bild, eller det är helt kört och att man får fundera på större installation om man vill ha det?
Det du kan göra är att leta reda på en Powerbank som kan laddas och användas samtidigt. Då kan du ha ett stort batteri som buffert medans bilen är avstängd. Bygger dock på att den hinner ladda Powerbanken medans du kör.
- danni
- Kontakt:
Nej, det kommer inte hända. Däremot aktiveras strömmen om du sätter på ventilationen i bilen remotely, så du får ta och göra det innan nån ska backa på diglobbin skrev:En fråga som vi inte har lyckats få svar på än
- vinothkannan
är det en konstant 12v-försörjning.. från Derek video...?..
kan jag filma när bilen är låst ..!!
MX100D-AP3-FSD
- spacemoose
Är DR900S värd pengarna eller ska man slå till på en DR750S nu när de är prissänkta?
Har 900:an några funktioner som inte går att leva utan förutom att det är högre upplösning?
Model 3 SR+ Refresh 2021 samt Model Y Performance 2024.
Model S 90D 2016 - såld.
Högre upplösning och nya h265-kodning (HEVC) som gör att 4K-filerna klarar sig på samma bitrate som 750-kameran.
Annars har 900s också större vidvinkel vilket jag i och för sig inte helt gillar då avståns till den framför blir svårare att avgöra för den som tittar på videon. Men kan ju vara bra om det händer nått lite snett framför en.
Sen har den betydligt snabbare wifi om man vill föra över filer till sin mobil via appen, och kan också spela upp en lite mer lågupplöst i mobilappen så att man typ direkt utan laddtid kan kolla igenom videofiler utan att behöva ladda ner.
750s är också en bra kameran så inte helt fel att köpa den. Man får fundera lite på om man tycker skillnaderna är värd den eller dom tusenlapparna.
- vinothkannan
FYI.. Mattias.. This is the best way to route the rear cable. without damaging.
MX100D-AP3-FSD
Får jag tillbaka min bil har jag en 750 till salu billigt då jag ska fixa 900.spacemoose skrev:Är DR900S värd pengarna eller ska man slå till på en DR750S nu när de är prissänkta?
Polestar 2 LRSM
3P vit/vit, ibland
3P vit/vit, ibland
Installerade min Dr900s igår och det vore ju trevligt med en snyggare lösning än att klistra upp den i rutan.helix skrev:Det här var en ganska trevlig lösning för alla som har en Blackvue. Blir en integrerad och diskret installation!
Priset är lite väl högt men annars vore den ju toppen om den fanns för ap1! Någon som sett något liknande för det?
Väntar på Tesla #3 (röd M3P)
