SVOLTs nya batterier
Postat: 30 sep 2020 08:08
https://pushevs.com/2020/09/29/svolt-un ... batteries/
E-platform (LFMP cathode)
This is the economic platform that uses the high-voltage version of LFP (LFMP) cathode chemistry. While LFP cells have a nominal voltage around 3,2 V, LFMP operates at 17 % higher voltage (3,75 V).
These battery cells are VDA compatible (148 mm of length).
Usage: mid-range electric cars
Cycle life: 4.000 cycles
Energy density: 20 % higher than LFP (above 200 Wh/kg)
Capacities: 90 and 115 Ah
Cost: 17 % cheaper than LFP (less than 60 euros per kWh)
Debut: 2021
Hypothetical battery pack 1 (90 Ah)
Cell disposition: 96s1p
Capacity: 32,4 kWh (96 x 3,75 V x 90 Ah)
Voltage: 360 V
Cost: below 3.000 euros (active and passive material)
